sums it up
Published date: May 15, 2012
  • Boat Type: Boat Type
When you get tired of people telling you its not a sailboat
Published by: davidsean
Model Year: 2003
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • New gate valve
    New gate valve
    Miscellaneous - - April 29, 2012
    Replaced old gate valve, with a larger 3" one. Published by: bugman
