Battery Monitor on the Cheap
- Boat Type: Boat Type
A digital VOM from Harbor Freight (cost $4.99) hard wired to aux DC house panel (more later on that). Good to 1/100th of a volt, it monitors charging voltage from shore-power AC charger, solar panel,and engine charging as well as discharge. Hook velcro from HomeD on back mounts it to the rug. Easy and cheap.
Published by: FPLynah
Related Mods
12V Plug, ScreenElectrical - - December 1, 2019
This picture shows a 12V plug that I added just inside the companionway, above the head door. There is a convenient, out of the way place in the corner in the corner of the head for the inside part of the plug. The wiring runs above the head door, th...
RewiringElectrical - - December 1, 2019
(A) is the power cables coming from the VHF and the compass. (B) is a bus bar that I glued onto the wall in the battery compartment. Wires run from the battery to this, and then to other circuits in the boat. I put a new heavier marine-grade cable fr...
No wiring other than the VHF power cords (I didn't do it) and a short wire from the fan are exposed in the interior. With patience, everything can be run through the conduits. All along the conduits are plastic hole covers from where the factory need...
