Inverter and Aux DC
- Boat Type: Boat Type
Under the aft setee seat, mounted on the wall I put a 500 watt inverter. I plugged a regular household extension cord into it and ran the end to under the table. We only use this AC to charge phones, Ipads, and laptops when on the hook. The aux panel is fused directly to the battery a/b switch. It is an unswitched 12 lug strip (6+, 6-) that supplies the (fused) inverter, a (fused) 12V socket under the setee, and the (fused) blower fan on the head. It also accepts the output from the solar panel controller to recharge battery one.
Published by: FPLynah
Related Mods
12V Plug, ScreenElectrical - - December 1, 2019
This picture shows a 12V plug that I added just inside the companionway, above the head door. There is a convenient, out of the way place in the corner in the corner of the head for the inside part of the plug. The wiring runs above the head door, th...
RewiringElectrical - - December 1, 2019
(A) is the power cables coming from the VHF and the compass. (B) is a bus bar that I glued onto the wall in the battery compartment. Wires run from the battery to this, and then to other circuits in the boat. I put a new heavier marine-grade cable fr...
No wiring other than the VHF power cords (I didn't do it) and a short wire from the fan are exposed in the interior. With patience, everything can be run through the conduits. All along the conduits are plastic hole covers from where the factory need...
