Drainage ???
Published date: June 20, 2012
  • Boat Type: Boat Type
I really can't believe I haven't seen this here before. I drilled out and replaced the teenie-tiny, lettle-bitty, microscopic drain in the engine well and replaced it with 1 1/4" ID fittings and hose. Bed it all w 5200 and all is good.......it drains!
Published by: FPLynah
Model Year: 2009
Photo Caption: the drain on the transom
Share
Related Mods
  • Bilge pump
    Bilge pump
  • Faucet
    Faucet
  • Water tank and deck fitting
