Genoa tracks
Published date: August 29, 2012
  • Boat Type: Boat Type
Installed 1-1/4 T-tracks and Garhauer genoa blocks. Bolted tracks through deck drilling oversize holes, filling with epoxy, and when hard, re-drilling to size. Used 3M 5200 for caulking. Holes remained right above the internal longitudinal ceiling mold, so bolts do not protrude inside through the ceiling. Large holes were made along the ceiling mold, right underneath each bolt, to fit washer, lock nut and wrench to tighten. These holes were covered with white plastic plugs as used everywhere else inside the boat.
Published by: Madelon
Model Year: 1994
Share
Related Mods
  • Teak treads on the swim ladder
    Exterior - - December 1, 2019
    The standard swim ladder is not very comfortable to use. So I added teak treads when I realized that such a thing were readily available, perfectly shaped below to fit onto the stainless steel tubes. Cost: $7 plus 4 SS screws and som 3M 5200 (or simi...
  • Doors
    Doors
    I purchased the boat used from a guy who had put two plexiglass doors (tinted) to replace the entranceway hatch/door on the original. These open outwards, and are made up of two identically shaped sections, one left and one right, essentially splitti...
  • Vents
    Vents
    I found after having my 26x anchored in Monroe Harbor in Chicago for two seasons that mildew buildup was a problem, as was a musty smell. I have now installed four vents. The first is in the forward hatch, and it is a common plastic vent from West Ma...
