Honda impella replacement
Published date: September 23, 2012
  • Boat Type: Boat Type
Just wanted to give heads up on changeing impella and parts required.
When you change the impella and gaskets , be sure you have all the fins in same rotation. This can be a little tricky as you need to put in the T pin within 1/2 inch space and without knowing you can counter rotate the impella to line up this pin.
I removed mine and saw 2 blades going oposite direction.
This will cause much less water going thru system and cause over heating.(I have had this in since last change almost 3 years ago)
It was probably my fault from last impella change as I didn't make sure all impellas were going same direction.
Also there is a rubber fitting over the expell tube, make sure it's there (mine was gone)
I also replaced the thermostate that also requires a gasket. When apart I put a high pressure hose in both chambers to flush out. I than filled with White vinigar ,let it set for 20 min. than added the new gasket and thermostate with a very clean edge.
Restarted and never in 4 years had this great of flow from P hole.
Published by: DaveB
Model Year: 1997
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • sums it up
    sums it up
    Miscellaneous - - May 15, 2012
    When you get tired of people telling you its not a sailboat Published by: davidsean
