Daggerboard Replacement
Published date: October 4, 2012
  • Boat Type: Boat Type
When i got my boat to Mazatlan i didnt notice that the daggerboard was damaged, soon after the maiden sail it broke flush to the hull, after several eforts to solve the problem since in Mexico we have no spare parts i went to a fiberglass artisan and together we designed in plywood a new one to make a mold and then finaly asemble a new one, wich has a special way to built it. First you need 2 halves prepared, the central section requires a wood beam covered with resin. I atached some photos. If anyone need a daggerboard in mexico i will be happy to help you with one, the cost was about 250 dollars.
Works as well as the original one with minor improvments, i am thinking of adding some weight to improve sailing performance.
Best regards
Published by: Kokani
Model Year: 1988
Photo Caption: Mold
finished daggerboard
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Honda impella replacement
    Miscellaneous - - September 23, 2012
    Just wanted to give heads up on changeing impella and parts required. When you change the impella and gaskets , be sure you have all the fins in same rotation. This can be a little tricky as you need to put in the T pin within 1/2 inch space and with...
