Cockpit and hatchway headroom with mast down
- Boat Type: Boat Type
It is not easy to go down below, or even move in the cockpit in MOST boats, with the mast down.
For no extra cost, a standard gin pole can find a second purpose in helping to create some cockpit space.
In the photos included, the standard bolt holds the base of the the gin pole to the cockpit rail.
One loop of rope holds the upper end of the gin pole in place, and two guy lines support it. The port guy line is part of the standard gin pole set up. The starboard guy line employs the otherwise unused mainsheet (remember: mast is down : ) -- tightened snugly.
The aft (lower) end of the mast is secured to the bow pulpit, bolted in, just as for travel.
Finally, the winchline, looped around the mast, supports the mast from the gin pole -- well overhead, and creating space to open the hatchway. I did not use this loop to actually lift the mast up -- that could cause a lot of chaffing, etc. I have not used this set up under way with power, yet, either. It may require some padding for the furling system, and in other places. It may require extra support for the dynamic loads, as well. But for messing around, doing work in the driveway, etc, it is handy. Hope this helps others.
- Bruce
Published by: BruceK
Related Mods
Cockpit Queen size bedCockpit - - December 1, 2019
Its usually too warm around Corpus Christi to sleep inside our cabin when we travel and anchor somewhere to sleep. The solution is simple. Mount six one inch strips of wood 6- ten inches long, which have had one edge rounded, to 3/4 of an inch below ...
Autohelm (Sort - of)Cockpit - - December 1, 2019
Here's a real HIGH TECH autohelm.... Sometimes I am sailing alone, have the boat going straight & even, & want to go down below for a few minutes (or maybe just for a beer). I have put one of the little eye-straps below the steering wheel, and I run ...
Winch Handle PocketCockpit - - December 1, 2019
See the attached where we placed a winch handle pocket. It is easy to find, and the pocket is always right where you need it (near the winches). Also note one of the doors that were constructed with the vent in the door. These are made of tinted plex...
