Hinged dining table
- Boat Type: Boat Type
I cut the table down & added a brass piano hinge. Now the table can be used as a half table for when more room is required. Table looks like it's not level when folded but it is. It will stay propped up against the hull liner groove even when heeling at 30 deg to starboard. I had to shift the leg support & add a quick release pin & R clip for the support leg.
Published by: Buell_S1W
Related Mods
Front SpeakersInterior - - December 1, 2019
We installed speakers in the vertical surfaces just above the v-berth. I would advise some caution when cutting the fiberglass as it is quite thin. Be sure to put the styrofoam back up in behind the speakers for floatation and to avoid the speakers s...
Communications/entertainmentInterior - - December 1, 2019
Greetings from Melbourne, Australia! I wanted to add music (radio/cassette/CD stacker) to 'Macanudo', my '97 26X. A 27Mhz radio was already installed hanging from a bracket just inside the companionway (hence there was power). It seemed a practical s...
