Lighting in rear berth
Published date: December 29, 2012
  • Boat Type: Boat Type
The light output of these fluorescents is phenominal. The backing plates are oak and secured by a bar with a thread tapped in it through the winch mounting access hole. This clamps the wood to the fibreglass without showing any visible attachent & makes access to the area behind them a breeze. I fitted one on each side, Port side shown here which really enhances vision over radio area & galley when it is slid back. Fluorescent doesn't create radio interference like previous older types did & light is individually switched if required anyway.
Published by: Buell_S1W
Model Year: 2009
Photo Caption: Port / galley light
Share
Related Mods
  • Anchor Light and Windvane
    Lighting - - December 1, 2019
  • Light In Head
    Light In Head
  • Light in the headroom
