LED Anchor light
Published date: December 29, 2012
  • Boat Type: Boat Type
I modified this Hella anchor light that takes an incandescent 10w bulb by spiraling up a length of LED ribbon & gluing it inside the lens & soldering to the connectors. The light output is fantastic due to the lens optics. Low current draw & much brighter than with a conventional bulb. This was much cheaper than buying Hella's LED anchor light.
Published by: Buell_S1W
Model Year: 2009
Photo Caption: LED anchor light
Share
Related Mods
  • Anchor Light and Windvane
    Lighting - - December 1, 2019
  • Light In Head
    Light In Head
  • Light in the headroom
