Micro Wind Turbine Generator (Project in Progress)
Published date: January 28, 2013
  • Boat Type: Boat Type
I purchased Cyber 150 Micro Wind Turbine (150 Watts) in picture #1 from Ebay, which is designed to produce a maximum of 30vdc and 5 amps, includes blocking diode, has a 22" rotation diameter, weighs 3.5 pounds and requires a 3/4" mounting pole.
Currently trying to determine proper mast support configuration and have posted both options for testing and will update with progress.
The end result is to connect to wind/solar hybrid controller to battery and load.
I am currently trying the mounting example configurations in picture #2.
***Update: Test Result Findings - Prior to performing the effort to install, I wanted to get some performance readings for wind speed vs voltage/amps output. I did this by holding the generator outside my car window while driving between 15mph - 30mph and clipped to a Multimeter. The output was confirmed to be DC (not AC).
-Driving at 15mph, voltage varied between 12v and 19v with about 1 amp.
-Driving at 30mph, voltage was surprisingly less at 12v to 15v with about 1 amp (not sure why it was less at higher speeds...maybe windshield was deflecting windstream?)
Since the test results were positive, I will proceed with a mast mount and provide updates. Also, to give you an idea how small this device is, check out the updated photo #1, which is me holding the generator I tested.
Link to Forum Topic
http://www.macgregorsailors.com/forum/viewtopic.php?f=8&t=21447&p=257351#p257351
Published by: macr
Model Year: 1996
Share
Related Mods
  • Electrical outlet near the dinette
    Electrical - (MacGregor 26X) - December 1, 2019
    A power outlet in the corner headroom/aft dinett seat/hull for mobile phone and everything else you might use while sitting by the dinett. Published by: MS Classifieds
  • Solar panels
    Solar panels
    Electrical - - December 1, 2019
    I installed 2 SOLAREX MSX 30 LITE solar panels on the hatch. They fit perfectly and leave enough space on each side for a teak grab rail in the future. Right now the panels are oversized (from the power point of view) since I do not have any big cons...
  • Lights & Electrical System
    We put in two additional interior lights. One over the rear berth, and one in the head. both are white plastic from West Marine, and have both the white and red bulbs (red reduces the impact on your night vision when you turn in on). The one in the h...
