Pedestal Compass & GPS
Published date: December 1, 2019
  • Boat Type: Boat Type
I mounted a Ritchie Explorer Compass to the top of the pedestal on my '99 Mac 26X. As you can see in the picture I have a pedestal guard and table from Havencraft. To that I mounted a Edson mount that only attaches to one leg of the guard. This gave me a platform to mount the Garmin combination GPS Chartplotter and Depth/fishfinder. The Edson mount can be swiveled to the angle you would like. The wires for the GPS exit the hole in the pedestal the same place the cables for the motor remote do and snake up behind the pedestal guard. I attached them to the pedestal guard with wire ties. The depth/fishfinder transducer is the transom type mounted under the cooler in a bed of plumbers putty shooting through the hull. Works fine there.
Published by: MS Classifieds
Model Year: 1999
Share
Related Mods
  • VHF Radio, Hooks
    VHF Radio, Hooks
    Instruments - - December 1, 2019
    (A) shows the VHF radio we had installed. The guy doing the installation ran into the lower-upper liner problem and decided to just run the power lines outside the wall for a short distance from the upper liner and then into the side of the house bat...
  • VHF Antenna
    VHF Antenna
    The VHF antenna cable (B) passes through the deck near the mast base. When you drill you hole for the cable, you have to watch for two things: * Make sure that you drill far enough to the side so that you do not hit the metal backing plate (A). * Mak...
  • VHF Antenna
    VHF Antenna
    This shows where the antenna cable exits the deck. It comes out right next to the conterboard cable without rubbing against it. This end connects with the antenna cable exiting the mast on the same side. To get the coaxial antenna cable to come out t...
