Hot Shower with option for solar heating
Published date: February 22, 2013
  • Boat Type: Boat Type
Home Depot / Walmart carries 2 or 2.5 gallon sprayer for less than $20. Heat the water in a pot on the stove and fill sprayer or leverage solar on deck to heat the black container in the sun.
Published by: macr
Model Year: 1996
Share
Related Mods
  • Bilge pump
    Bilge pump
  • Faucet
    Faucet
  • Water tank and deck fitting
