Avoiding sun-glare
Published date: February 26, 2013
  • Boat Type: Boat Type
I installed a regular window-shade to block the low standing sun on mornings and evenings and to provide shade during the day. Since the companionway is not that high, there is enough material on the roll to cut off soiled sections when needed.
Published by: Obelix
Model Year: 2008
Photo Caption: Shade-1
Shade-2
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Daggerboard Replacement
    Miscellaneous - - October 4, 2012
    When i got my boat to Mazatlan i didnt notice that the daggerboard was damaged, soon after the maiden sail it broke flush to the hull, after several eforts to solve the problem since in Mexico we have no spare parts i went to a fiberglass artisan and...
