Anchor light installation (Part 1)
Published date: March 10, 2013
  • Boat Type: Boat Type
I created a 32 feet long drill-set since I didn't know how much foam is in the mast. I used a 48" long flexible drill (3/8") from HF as starter and 7 each 3/16" steel rods (48" long) from HD and cut 10-24 treads for about 1" at each end. Then I made 7 couplers out of 3/8" aluminum-rod from HD and cut inside treads. The whole set screws together as you go and you only work with unsupported 48" of drill at any time.
First I removed the bottom piece of the mast and then drilled out the rivets holding the mast-cap. Later I closed the rivet-holes with electrical tape and drilled and tapped new holes for 8-32 screws. The actual drilling for the wires went really smooth since there are only about 12-15 feet of foam on the top of the mast.
Published by: Obelix
Model Year: 2008
Photo Caption: Drill-Set
Connecting another rod
Drilling complete
Share
Related Mods
  • Electrical outlet near the dinette
    Electrical - (MacGregor 26X) - December 1, 2019
    A power outlet in the corner headroom/aft dinett seat/hull for mobile phone and everything else you might use while sitting by the dinett. Published by: MS Classifieds
  • Solar panels
    Solar panels
    Electrical - - December 1, 2019
    I installed 2 SOLAREX MSX 30 LITE solar panels on the hatch. They fit perfectly and leave enough space on each side for a teak grab rail in the future. Right now the panels are oversized (from the power point of view) since I do not have any big cons...
  • Lights & Electrical System
    We put in two additional interior lights. One over the rear berth, and one in the head. both are white plastic from West Marine, and have both the white and red bulbs (red reduces the impact on your night vision when you turn in on). The one in the h...
