trailer brakes
Published date: April 12, 2013
  • Boat Type: Boat Type
Bought my boat last November, it needed a lot of work. The factory drum brakes were junk. Good brakes being very important to me, I went all out for Kodiac's all stainless disc brake conversion, with floating rotors and new hubs with bearings and bearing buddies. I modified the master cylinder to work with the disc setup, after rebuilding it. This only required removing a valve inside. Also added a reverse lock-out solenoid, which I stepped on and broke my first time out. I'm now using a bolt thru the sliding tongue, to prevent master cylinder action, when I need to back-up. It works great! Even towing down hill. I can't feel the load behind me.
Published by: Capt Smitty
Model Year: 2002
Photo Caption: Kodiac, all SS, vented rotors
On left end of spring is rubber valve I removed
Share
Related Mods
  • Dual axle trailer
    Dual axle trailer
    Trailer - - December 1, 2019
    One of the first mods I made was to add a second axle to the trailer. I just felt more confortable with the added margin. I also knew I was going to add a fair amount of weight (three batteries total, 4-stroke engine, 24 gallon fuel, etc.). Although ...
  • Trailer tie down blocks
    Trailer - - March 8, 2013
    It is important to tie down the boat to the trailer, but one thing you do want to happen is for the straps to beat the boat up as you're cruising down the highway. To prevent the straps from hitting Sheilagene 2's fancy new paint job I fabricated a f...
  • Trailer post foam pads
    Here is a simple mod that is worth doing on the standard MacGregor trailer. I purchased some foam water pipe insulation to cover the aft trailer posts. If you purchase 1 5/8" inside diameter insulation it will fit perfectly, the natural curve in the ...
