Broken Keel wire
Published date: June 1, 2013
  • Boat Type: Boat Type
I was sailing the other day and my keel wire broke. Can I put a new wire while the boat is in the water? I have the boat on a mooring and can dive . I see the old wire still attach to the keel but it is broken about 4 feet from where it attaches
Published by: PlumLoco
Model Year: 1981
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Mac 26M Parts drawings link
    Miscellaneous - - March 18, 2013
    Here is a link to the MacGregor FACTORY web page. http://www.macgregor26.com/suppliers_corner/commodity_list.html (Called suppliers corner) It has the technical drawings of all the SS parts that make up the rigging and a list of materials required to...
