Conduit to the Other Side.....P.2
- Boat Type: Boat Type
Glamour Shots
The first photo shows where the conduits terminate under the sink, after passing through the ledge at the back of the porta-potti
The second photo shows the conduit installed up\down in the head with two 90 degree junction boxes installed.
The last photo shows the conduit coming from the upper junction box in the head and into the flotation compartment above the sink.
For the how to please see part 1
http://www.macgregorsailors.com/modt/index.php?view=1885
Note: Many people remove the foam in the upper box over the galley and place it in gaps under the sink. This may not be a good idea due to moving flotation forces to the lower half of the boat.
As home made boats with foam in the floor only, float upside down when flooded.
JMHO
Martin
flotation foam
Published by: martyr
Related Mods
Electrical outlet near the dinetteElectrical - (MacGregor 26X) - December 1, 2019
A power outlet in the corner headroom/aft dinett seat/hull for mobile phone and everything else you might use while sitting by the dinett. Published by: MS Classifieds
Solar panelsElectrical - - December 1, 2019
I installed 2 SOLAREX MSX 30 LITE solar panels on the hatch. They fit perfectly and leave enough space on each side for a teak grab rail in the future. Right now the panels are oversized (from the power point of view) since I do not have any big cons...
Lights & Electrical SystemElectrical - - December 1, 2019
We put in two additional interior lights. One over the rear berth, and one in the head. both are white plastic from West Marine, and have both the white and red bulbs (red reduces the impact on your night vision when you turn in on). The one in the h...
