Trailer tie-down
Published date: October 10, 2013
  • Boat Type: Boat Type
This is how i tie the boat to the trailer.
I installed a cleat on the trailer frame, and I use two mooring-lines to
tie the boat.
First the mooring-line is looped around the mast, then it goes to the aft cleat secured with a turn,
then to the cleat on the trailer also with a turn to secure it and last a turn around the winch and it
is held tight with the cam-cleat for the jibsheet.
This is simple and easy, and it is making use of ropes already on the boat.
Published by: Norca
Model Year: 2011
Share
Related Mods
  • Dual axle trailer
    Dual axle trailer
    Trailer - - December 1, 2019
    One of the first mods I made was to add a second axle to the trailer. I just felt more confortable with the added margin. I also knew I was going to add a fair amount of weight (three batteries total, 4-stroke engine, 24 gallon fuel, etc.). Although ...
  • Combo bike rack and spare tire mount
    Trailer - - August 6, 2013
    I wanted to be able to bring a couple of bicycles along with the boat from time to time, and needed a spare tire mount anyway, so I made my own. While there are adapters that plug into the tow vehicle's receiver and provide a second, light-duty recei...
  • Boat off of trailer
    Boat off of trailer
    Trailer - - July 15, 2013
    This is how I'm doing it. I use 2 floor jacks to raise rear of trailer high enough to slide the rear cradle under the hull, then lower trailer and use the tongue jack to raise the front. Only takes a few minutes and is very stable. I still have to ma...
