Trailer Tie Down Point
Published date: October 24, 2013
  • Boat Type: Boat Type
One of my first mods. Fairly simple with no holes drilled and easy to do. I attached a stainless steel eye on each side of the rear of the trailer replacing one of the cross member securing bolts with a longer bolt of same diameter.
Published by: Sea Shadow
Model Year: 2011
Share
Related Mods
  • Dual axle trailer
    Dual axle trailer
    Trailer - - December 1, 2019
    One of the first mods I made was to add a second axle to the trailer. I just felt more confortable with the added margin. I also knew I was going to add a fair amount of weight (three batteries total, 4-stroke engine, 24 gallon fuel, etc.). Although ...
  • Trailer tie-down
    Trailer tie-down
    Trailer - - October 10, 2013
    This is how i tie the boat to the trailer. I installed a cleat on the trailer frame, and I use two mooring-lines to tie the boat. First the mooring-line is looped around the mast, then it goes to the aft cleat secured with a turn, then to the cleat o...
  • Combo bike rack and spare tire mount
    Trailer - - August 6, 2013
    I wanted to be able to bring a couple of bicycles along with the boat from time to time, and needed a spare tire mount anyway, so I made my own. While there are adapters that plug into the tow vehicle's receiver and provide a second, light-duty recei...
