Shore power input
- Boat Type: Boat Type
Didn't like having to drape an extension cord through the hatch to connect to my permanently mounted charger in the boat. Had to watch every time I closed the hatch not to catch the cord also not real happy about rain etc. and not protected connection. Fitted a Clipsal IPV6 socket (male end) on the port side of the transom entry way just under the fold down seat. Also attached a screw on female socket to the extension cord - nice waterproof connection when drawing mains power to charge batteries. I got access to to do the fitting via factory fitted access hatch, remove flotation, wire up and fit inlet, replace flotation and replace access hatch cover.
Published by: Sea Shadow
Related Mods
Electrical outlet near the dinetteElectrical - (MacGregor 26X) - December 1, 2019
A power outlet in the corner headroom/aft dinett seat/hull for mobile phone and everything else you might use while sitting by the dinett. Published by: MS Classifieds
Solar panelsElectrical - - December 1, 2019
I installed 2 SOLAREX MSX 30 LITE solar panels on the hatch. They fit perfectly and leave enough space on each side for a teak grab rail in the future. Right now the panels are oversized (from the power point of view) since I do not have any big cons...
Lights & Electrical SystemElectrical - - December 1, 2019
We put in two additional interior lights. One over the rear berth, and one in the head. both are white plastic from West Marine, and have both the white and red bulbs (red reduces the impact on your night vision when you turn in on). The one in the h...
