Rudder Re-Do
Published date: January 15, 2014
  • Boat Type: Boat Type
I recently purchased an older model Mac22 from someone who liked to be creative and make his own fixes. One item he "fixed" was the rudder. He fiberglassed the two parts with numerous layers,making each piece a good 20+ lbs each. Then he added 2 zinc plates, each weighing another 20 lbs, at the pivoting point. I simply cannot handle the rudder, when necessary, because of the excessive weight. I somewhat understand the idea of the sacrificial metal and would like to know if I could replace the zinc plates with something else, like stainless, to reduce the weight and still have a functional, corrosion-resistant rudder. If that won't work, where can I purchase an inexpensive replacement rudder?
Published by: mac22+
Model Year: 1978
Share
Related Mods
  • Andersen stainless sheet winches
    Sailing - - December 29, 2012
    Quality Andersen winches made in Denmark. Stainless tops, brass bases & proper bearings inside. These are their # 10 & fit almost straight on, very little clearancing of the oem mounting holes required. I use one for raising my steel daggerboard (see...
  • Ballast tank vent
    Ballast tank vent
    Eliminate that cheesy rubber / tinfoil stopper for the ballast tank vent. Simple On / Off valve $10-15 worth of parts at a plumbing store. With the raised stand pipe no water burps into the collector funnel which means no need to mop anything up. Pub...
  • See windvane with bimini up
    Sailing - - August 31, 2012
    Have a bimini permanently mounted on a radar arch. installed telltales on upper shrounds but not exactly dependable in light winds. Thought about installing window in bimini but that would still require crooking neck upward. So came up with this mod ...
