Outboard Replacement
Published date: February 12, 2014
  • Boat Type: Boat Type
I had some stressfull experiences with my 2 cycle 10 hp evinrude engine since it didnt had the adequate propeller (i guess) it hardly reached 6.2 knt at full trhottle and althogh it was long shaft it got out off the water in seas with 7 ft waves, i had searched for
a 4 cycle engine and i found this 20 hp at the same Price as a 9.9, and since i was in a hurry i thoght the extra hp could be of use some time, when i finally tested the outboard it pushed silently the boat at 7 knts at half trottle but when i whent to WOT it hardly reached 8 and was very hard to control, i later learned that the proper pitch propeler may move the boat with the 10hp at lower revs.
If anyone is tempted to install a 20 it does fit in the well with minor modifiations to properly turn and be lifted out of the water, and the extra weight seems to help a Little with big waves.
A nice feature is thet it has a standard 6 amp electric generator that charges my battery, wich i moved under the "V" berth to compensate the extra weight of the engine.
Published by: Kokani
Model Year: 1989
Share
Related Mods
  • Steering Connector and Drainage Holes
    Motor - - December 1, 2019
    This picture shows the custom-built connector from the steering system to the engine. We started with a connector from the dealer, but it didn't fit right. We had a welder build a new one, and it works great! We leave the engine and rudders both conn...
  • Gas Tanks - Installation & Draining
    Note gas tanks on either side - these were there when I bought the boat. I believe they are 9 gallon tanks. The past owner had do some minor cutting to the openings to get them in. From there, he cut holes in the seat, put those plastic screw plugs i...
  • Electric Drive Kick-up Rudder
    Motor - - September 2, 2013
    In an effort to improve low speed performance, I took an old "Trolling Motor" and disassembled it and sandwiched it between two 5/8" pieces of board modified to mirror the size shape of the factory lower rudder section. I used fiberglass and epoxy ov...
