Solar Power - off the grid
Published date: May 13, 2014
  • Boat Type: Boat Type
This year we plan on slipping our boat on a lake which does not have power at the docks, so we needed a way to recover our batteries durring our weekend outings. Trying to keep it simple was the idea in this mod. The primary support structure is the aft mast support bracket. (See my last post on Mast Support Shims - to limit the play in the bracket)
I used a single 100W panel which connects to the top of the mast support with adel clamps and uses stainless tubing and couplings (typical bimini construction) for the aft support. I made a small hole in the mast support bracket near the top and snaked the wire through so it is barely detectable.
Chris.
Published by: u12fly
Model Year: 2006
Photo Caption: Solar Panel attached to mast support bracket
Underside view of the Solar Panel
Wiring routes through the mast bracket and then into the hull
Share
Related Mods
  • Electrical outlet near the dinette
    Electrical - (MacGregor 26X) - December 1, 2019
    A power outlet in the corner headroom/aft dinett seat/hull for mobile phone and everything else you might use while sitting by the dinett. Published by: MS Classifieds
  • Solar panels
    Solar panels
    Electrical - - December 1, 2019
    I installed 2 SOLAREX MSX 30 LITE solar panels on the hatch. They fit perfectly and leave enough space on each side for a teak grab rail in the future. Right now the panels are oversized (from the power point of view) since I do not have any big cons...
  • Lights & Electrical System
    We put in two additional interior lights. One over the rear berth, and one in the head. both are white plastic from West Marine, and have both the white and red bulbs (red reduces the impact on your night vision when you turn in on). The one in the h...
