Skylight hatch install
- Boat Type: Boat Type
I added these two small opening hatches to my boat. I bought a new set of plastic skylights and glued them over the existing skylights, then cut out the opening for the hatch. The hatches are made of black plastic with tempered glass. I used a trim ring made of black starboard under each hatch.
These let in plenty of air. I installed the hatches facing the sides of the boat so when at a dock there is cross ventilation. I used plenty of black silicone to bed everything with and did not torque stuff down hard. Everything conformed to the gentle curve of the original skylights
Published by: Ixneigh
Related Mods
Front SpeakersInterior - - December 1, 2019
We installed speakers in the vertical surfaces just above the v-berth. I would advise some caution when cutting the fiberglass as it is quite thin. Be sure to put the styrofoam back up in behind the speakers for floatation and to avoid the speakers s...
Communications/entertainmentInterior - - December 1, 2019
Greetings from Melbourne, Australia! I wanted to add music (radio/cassette/CD stacker) to 'Macanudo', my '97 26X. A 27Mhz radio was already installed hanging from a bracket just inside the companionway (hence there was power). It seemed a practical s...
