Speed up your enclosure assembly
Published date: February 8, 2015
  • Boat Type: Boat Type
If you have a full canvas enclosure, like me, you might struggle with deploying it, trying to figure out which panel goes where, and how to orient them.
I bought two rolls of coloured electrical tape and attached swatches to each corner of each panel.
- RED TRIANGLE: This corner of this panel goes on PORT side toward POINTY end of boat.
- RED SQUARE: This corner of this panel goes on PORT side toward BLUNT end of boat.
- GREEN TRIANGLE: This corner of this panel goes on STARBOARD side POINTY pointy end of boat.
- GREEN SQUARE: This corner of this panel goes on STARBOARD side toward BLUNT end of boat.
Though this doesn't tell you which piece you are holding, it allows you to instantly orient the panel correctly as you pull it out of storage and unfold it, and figuring out which one it is follows very easily.
Published by: DaveC426913
Model Year: 2000
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Mac washing machine
    Mac washing machine
    Miscellaneous - - December 18, 2013
    No need to carry a heavy washing machine or look for laundymats. A toilet plunger and five gallon bucket work really well. Here's the proof. Published by: Al Garrett
