Autopilot, Raymarine
Published date: May 10, 2015
  • Boat Type: Boat Type
Following the lead of numerous other MacGregor owners I opted to install the Raymarine EV-1 Autopilot. I went with the tiller-pilot version so I could mount the actuator below decks and not have to listen to it while sailing. I got it out for the first time today and it was perfect. I chose to mount the ACU-100 control and the EV-1 sensor in the Port Aft storage area under the galley when it is fully aft. With the NMEA cabling provided in the kit, I found this was the best place for me to install it unless I wanted to buy more cabling. I'm still a bit uncertain about the mount for the actuator. I epoxied a 2x4" piece of treated lumber to the hull on the starboard side to mount the actuator to. I'm not certain there is enough surface area for a 2x4 bonded end-on. Others have used a 4x4" and have twice the surface area. So far, no issues but I will be keeping an eye on it
Published by: jstyers
Model Year: 2005
Photo Caption: Managing 5+ knots boatspeed on a nice reach
ACU-100 Installed in storage area under most aft galley position
EV-1 sensor mounted in storage area under most aft galley position
Share
Related Mods
  • VHF Radio, Hooks
    VHF Radio, Hooks
    Instruments - - December 1, 2019
    (A) shows the VHF radio we had installed. The guy doing the installation ran into the lower-upper liner problem and decided to just run the power lines outside the wall for a short distance from the upper liner and then into the side of the house bat...
  • VHF Antenna
    VHF Antenna
    The VHF antenna cable (B) passes through the deck near the mast base. When you drill you hole for the cable, you have to watch for two things: * Make sure that you drill far enough to the side so that you do not hit the metal backing plate (A). * Mak...
  • VHF Antenna
    VHF Antenna
    This shows where the antenna cable exits the deck. It comes out right next to the conterboard cable without rubbing against it. This end connects with the antenna cable exiting the mast on the same side. To get the coaxial antenna cable to come out t...
