Electrical Rework
Published date: May 21, 2015
  • Boat Type: Boat Type
The first picture shows a "splice" found among the rats-nest of wires down aft of the port battery. Needless to say, all of it had to go and I mostly started from scratch with the wiring. most of the actual wire runs through out the hull were left in place, but every single wire was re-terminated.
The old fuse block was too corroded to even replace any of the fuses, so it was pulled & replaced by primary and auxiliary circuit breaker panels. The aux panel was mounted starboard side aft of the dinette.
The 110V outlet was replaced by a new water resistant GFCI one. Also added into the shore power circuit was a battery charger/conditioner.
All of the interior lights were replaced with LED fixtures. A LED light fixture was also added in the head (novel concept, all Admirals would approve).
3 new 12V outlets were installed (2 on aux panel and 1 aft of the stove). There was one rusty one already mounted, but I couldn't tell if it was original or added by a PO.
Lastly the batteries were placed in marine battery boxes and strapped down.
Published by: DHK79
Model Year: 2000
Photo Caption: Any electrical engineer would be proud
Share
Related Mods
  • Electrical outlet near the dinette
    Electrical - (MacGregor 26X) - December 1, 2019
    A power outlet in the corner headroom/aft dinett seat/hull for mobile phone and everything else you might use while sitting by the dinett. Published by: MS Classifieds
  • Solar panels
    Solar panels
    Electrical - - December 1, 2019
    I installed 2 SOLAREX MSX 30 LITE solar panels on the hatch. They fit perfectly and leave enough space on each side for a teak grab rail in the future. Right now the panels are oversized (from the power point of view) since I do not have any big cons...
  • Lights & Electrical System
    We put in two additional interior lights. One over the rear berth, and one in the head. both are white plastic from West Marine, and have both the white and red bulbs (red reduces the impact on your night vision when you turn in on). The one in the h...
