Anchor Light and Windvane
Published date: December 1, 2019
  • Boat Type: Boat Type
This picture shows the mount for the anchor light and windvane. We
didn't have a mast cap, so I used a piece of plexiglass (B) that
I mounted on the brackets that the backstay attaches to.
I picked plexiglass
because it was handy, and it doesn't stand out too much. I'll
probably replace it with a better mast cover sometime. The anchor
light (C) is mounted in the center, and the Windex windvane (A)
is mounted up
and aft so that it is easy to read from the cockpit while sailing, and
so that it gets less interference from the rest of the stuff up there.
To avoid having to install another through-deck and switch, the anchor
light and steaming light can alternately be plugged into the same
connector labeled "mast light" and controlled from the front panel.
This works fine since the two uses are mutually exclusive and it's not
too much of a pain to unplug one and plug in the other.
Since this picture was taken, I have added a VHF antenna mounted on
the front of the mast.
Published by: Heath
Model Year: 1997
Share
  • This site is not responsible for damage done to your boat.
  • When in doubt, consult a professional. Always comply with local and marine codes.
  • Dont drill holes in the bottom of your boat.
  • Happy sailing
Related listings
  • Light In Head
    Light In Head
    Lighting - - December 1, 2019
  • Light in the headroom
  • New light for the head.
    Lighting - - May 9, 2017
    I installed a new light for the head with the switch on the top right corner of the plastic cabinet door. It's so my kids can reach it. All the lights in the boat are LED as are the nav and mast lights now. Published by: silverfox441
