Dual axle trailer
- Boat Type: Boat Type
One of the first mods I made was to add a second axle to the trailer. I just felt more confortable with the added margin. I also knew I was going to add a fair amount of weight (three batteries total, 4-stroke engine, 24 gallon fuel, etc.). Although you can't see it here I also added a fresh water flush for the brakes that I use at the ramp after dunking the trailer in the salt water. I had the second axle added by a local trailer supplier.
Published by: MS Classifieds
Related Mods
Another Furler SupportTrailer - Furler (MacGregor 26M) - January 17, 2020
4" PVC pipe with 1/8" x 3/4" aluminum straps. Velcro straps attach support to mast and furler to support. Finally losing the crutch!
goal post rollersTrailer - - May 20, 2018
When my white hull hits one of the bare aluminum goal posts I get dark smudge marks that are very difficult to remove without abrasives. These PVC rollers eliminate smudges and allow the goal posts to also be used for guiding the boat on to the trail...
Trailer MoverTrailer - - October 25, 2017
I bought a new TrailerValet XL on Amazon. Make sure you order the newer one with "NO FLAT" tires! Great item that helps me slide toys into their tight spots & not hit that Blasted Fence! Aggghhh! I can't put pics up now. Here's an amazon link: https:...
