Hot Water System
Published date: July 9, 2015
  • Boat Type: Boat Type
Finally adding shore power and a long planned 2.5 gal hot water heater to our pressurized water system. Only draws 1440W so it will run off the Honda EU2000 generator.
Bought a mixing valve to mix down to 105 deg to extend the hot water and simplify the installation. Connected to both the transom and head showers. Head has a sump pump drain setup with a float valve in a Tupperware container hooked to the sink drain (see previous mods).
Water heater is a Rheem 2.5 point of use from Home Depot @ $205. Valve is from Amazon @ $37 (LightInTheBox 0912-PHW-02). Uses standard sink and plumbing fittings from Home Depot to end up with 3/8 hose barbs in and out. Water heater was reset to 135 deg.
Fits under forward dinning seat at 16.5" tall (top of blow offvalve). Only 9.5" diameter. Much smaller than it appears in the picture.
Published by: vkmaynard
Model Year: 2001
Share
Related Mods
  • Bilge pump
    Bilge pump
  • Faucet
    Faucet
  • Water tank and deck fitting
