Fishing Rod Rack, No Holes in the Boat
Published date: March 3, 2016
  • Boat Type: Boat Type
I've seen fishing rod racks put in this spot before and thought that it was a good use of the space. However, I don't like putting holes in my boat. Therefore, I adapted the method of sliding thin (about 1/4") veneer between the liner on the top side and using double sided tape on the bottom side from some mods that Chinook posted. The tape I used was left over from a car project. I remember it was really expensive, but I'd recommend any double sided foam tape. I think the thicker foam tape adheres better to the uneven surfaces.
Jeff
Published by: C Buchs
Model Year: 2001
Share
Related Mods
  • Front Speakers
    Front Speakers
    Interior - - December 1, 2019
    We installed speakers in the vertical surfaces just above the v-berth. I would advise some caution when cutting the fiberglass as it is quite thin. Be sure to put the styrofoam back up in behind the speakers for floatation and to avoid the speakers s...
  • Communications/entertainment
    Greetings from Melbourne, Australia! I wanted to add music (radio/cassette/CD stacker) to 'Macanudo', my '97 26X. A 27Mhz radio was already installed hanging from a bracket just inside the companionway (hence there was power). It seemed a practical s...
