Dinghy Storage and Cushions
Published date: March 26, 2016
  • Boat Type: Boat Type
We dislike having life jackets, water bottles and other stuff just rolling around in the dinghy. Could not find a dinghy seat cushion with storage that had a lot of good comments. So if you want to do it right do it yourself or better have your wife do it. So here is our cushion/storage bag. There are three pockets on each side and a pouch under the seat for life jackets. The seat cushion is dryfast foam and the material is a plastic type from sailrite.
Published by: ris
Model Year: 2003
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Speed up your enclosure assembly
    Miscellaneous - - February 8, 2015
    If you have a full canvas enclosure, like me, you might struggle with deploying it, trying to figure out which panel goes where, and how to orient them. I bought two rolls of coloured electrical tape and attached swatches to each corner of each panel...
