Skylight blinds
- Boat Type: Boat Type
This is a mod that I probably should have done a long time ago...
I found out about the OceanAir blinds from a mod posted by Knotshore.
My blinds are installed in a different direction though. Boat sent me a picture
of his OceanAir blinds mounted side to side (port to starboard) with the roller
mounted in the center.
I thought that this was a good option for the 26M since
there is some space between the liner and the hull in that location. Since there
is no access to get a nut inside of the liner I used two expansion nuts to mount
the rollers.
For the plastic retaining clip that holds the blind open there was no space between the
liner and the hull in that location so I had to use a different method. I used a
shorter 1/4" screw and Gorilla glue. You need to be very careful drilling in this
location since you could easily drill through both the liner and the hull. I drilled
a 3/16" depth pilot hole.
This is the shade that I ordered from ahoycaptain.com:
Oceanair Cabinshade Size 2 .(OA) CSH-2-B-RP
I paid an extra $10 to get beige instead of silver because I think it looks better.
Published by: Brian
Related Mods
Front SpeakersInterior - - December 1, 2019
We installed speakers in the vertical surfaces just above the v-berth. I would advise some caution when cutting the fiberglass as it is quite thin. Be sure to put the styrofoam back up in behind the speakers for floatation and to avoid the speakers s...
Communications/entertainmentInterior - - December 1, 2019
Greetings from Melbourne, Australia! I wanted to add music (radio/cassette/CD stacker) to 'Macanudo', my '97 26X. A 27Mhz radio was already installed hanging from a bracket just inside the companionway (hence there was power). It seemed a practical s...
