Hydraulic Steering Modification
Published date: July 21, 2016
  • Boat Type: Boat Type
I changed the steering on our 26X from the original cable steering to a hydraulic steering. The new steering is very smooth and accurate. The two main components I purchased as used items. The installation of the Seastar 1.7 helm pump required only minor modification after removing the cable steering. The hydraulic cylinder HC5345 is mounted on support blocks to the deck and is linked directly to the rudder actuation bar. The steering wheel ratio remained almost the same as with the cable steering at about 3.5 turns lock-to-lock.
Published by: Andysigrist
Model Year: 1996
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Dinghy Storage and Cushions
    Miscellaneous - - March 26, 2016
    We dislike having life jackets, water bottles and other stuff just rolling around in the dinghy. Could not find a dinghy seat cushion with storage that had a lot of good comments. So if you want to do it right do it yourself or better have your wife ...
