2:1 rudder single-loop uphaul downhaul
Published date: August 7, 2016
  • Boat Type: Boat Type
This is my implementation of the 2:1 mechanical advantage rudder lines.
A single loop is used for both uphaul and downhaul.
SeaSaw has stern-mounted seats, giving me a well-placed rail/stanchion around which the loop goes so it does not foul.
Published by: DaveC426913
Model Year: 2000
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Hydraulic Steering Modification
    Miscellaneous - - July 21, 2016
    I changed the steering on our 26X from the original cable steering to a hydraulic steering. The new steering is very smooth and accurate. The two main components I purchased as used items. The installation of the Seastar 1.7 helm pump required only m...
