Dutchman mainsail flaking system
Published date: August 25, 2016
  • Boat Type: Boat Type
Been trying to get my boat up to scratch to sail solo and dread going forward to drop the mainsail (or indeed raising it in the first place). Looked at the comments about lazy jacks (and started putting some together) when I came across the Dutchman sail flaking system. Had to get it from the States and of course bolts at imperial rather than metric) but finally had a sailmaker fit it for me. Supposed advantages over lazy jacks is that the lines do not foul with battens when raising or dropping sails, no need to adjust topping lift once set up, no extra lines for the jacks themselves. According to the directions, the sail needs to be "trained" to flake correctly into loose folds but my first couple of raisings and lowerings worked pretty well from the start. At this stage, I have only operated it in the driveway but come the nicer weather I am looking forward to testing it out on the water. Update: Well, I had it out on the water a couple of weeks ago and the system worked as advertised. Turned into the wind and dropped the main without major issues although at times I felt I need a downhaul just to help it along.
Published by: Sea Shadow
Model Year: 2011
Photo Caption: Dutchman system ready to raise mainsail.
Sail flaked as it dropped (minor assistance from cockpit)
Mainsail up from the cockpit.
Share
Related Mods
  • Quick Release Pins
    Quick Release Pins
    Rigging - - December 1, 2019
    We all hate to mess with clevis pins right? Try ball lock pins. I use 1/4 " x 2" pins on the boom/mast gooseneck connection, the tack of the main, and to fasten the roller reefing drum to the bow. Never had one come loose but I recommned using long p...
  • Cabin Top Traveler Install
    Rigging - - June 17, 2014
    I found a main sheet traveler and bridge removed from an Irwin 31 on Ebay. Trimmed it to fit my X cabin top. Haven't sailed with it yet, but I like how It took the sheets out of the cockpit; and gave me something to work my "wind / spray shield idea"...
  • Mast Support Shims
    Mast Support Shims
    Rigging - - May 4, 2014
    I use to pull off the mast support every time I put the boat into the water. But this year we are going to add a solar panel to the boat and I plan to attach it to the mast support. Issue is the dang thing is so sloppy it just is not stable enough to...
