Electrical Connections Board
- Boat Type: Boat Type
In order to get all our electrical connections readily accessible, we put this board up to the aft of the galley. We only have one battery bank of 4 Trojan 105 batteries so the large red switch is a on/off switch for all DC power. The large red fuse to the left of the on/off is on the line from the DC on/off to the main DC switch panel. The system negatives are combined in lower left of pic. The fuse panel to the right of the DC on/off is for the down stair systems there is another small fuse panel in the steering pedestal. The fuses in these panels are ATC fuses that glow when they short out. The white box on the top of the board is a Sterling Power 10 amp smart charger. Right of the charger is the Balmar Smartgauge for checking battery status. Under the Smartguage are a 12 volt power plug(our Engel Fridge plugs in here), the other is a double USB port. All our wiring connections are on this board or at the device. There is still plenty of room to add stuff to this board. There is about 3/4 of an inch of space behind the board to run wires.
Published by: ris
Related Mods
Electrical outlet near the dinetteElectrical - (MacGregor 26X) - December 1, 2019
A power outlet in the corner headroom/aft dinett seat/hull for mobile phone and everything else you might use while sitting by the dinett. Published by: MS Classifieds
Solar panelsElectrical - - December 1, 2019
I installed 2 SOLAREX MSX 30 LITE solar panels on the hatch. They fit perfectly and leave enough space on each side for a teak grab rail in the future. Right now the panels are oversized (from the power point of view) since I do not have any big cons...
Lights & Electrical SystemElectrical - - December 1, 2019
We put in two additional interior lights. One over the rear berth, and one in the head. both are white plastic from West Marine, and have both the white and red bulbs (red reduces the impact on your night vision when you turn in on). The one in the h...
