Curtains for head
Published date: March 26, 2017
  • Boat Type: Boat Type
The first year we had DoWe:797.124. Replaced the stock vinyl head curtain with a fabric one made from Covington McGregor Mariner (http://www.sailrite.com/Covington-McGregor-Mariner-54-Fabric, though I found my at Joann.com).
The reason is that the vinyl curtain was too stiff, wouldn't fold well when secured in the open position and blocked too much light.
It used curtain weights in the hem to keep it straight and a pocket hem at the top to utilize the stock curtain rod.
It worked fine for the first season, but if you try to stand and maneuver with the curtain closed, your head pushed the curtain into the companionway exposing half your body. We tie up with our bow facing the pedestrian walkway of our dock at our marina and if the front hatch is open you can chat with anyone walking by from that position.
For year two I installed two of Sailrite's Curtain Track Horizontal Mount Vinyl 48" (http://www.sailrite.com/Curtain-Track-Horizontal-Mount-Vinyl-48) across the top of the ceiling to either side of the skylights and in line with the head walls. I repositioned the first McGregor curtain on the track and sewed a new curtain, notched to accommodate the port settee, on the forward track.
This way you can pull both curtains across, starboard to port and expand the head space fully across the port side. This is really convenient when changing clothes either at the dock or with passengers on board.
Published by: Tattoo new
Model Year: 2015
Photo Caption: Track screwed in the ceiling
Aft curtain, stowed
forward curtain across vberth
Share
Related Mods
  • Self-Closing Head Door
    Head - - December 1, 2019
    Want to solve a real irritating situation, especially for those of the female persuasion? The head door flops around as it is, and trying to lock it from the inside when the boat is under sail or power can be a real pain. We put the self-closing hing...
  • C-head install
    C-head install
    Head - - November 19, 2016
    Installed C-head composting toilet this weekend. Very easy job. Did not get vent tank thingy ($40) or the t handle hold down thingys ($40). Won't need vent for storage tank as will be bringing compost home or be off shore 3+ miles. Found t handle hol...
  • Water Sys Fix
    Water Sys Fix
    Head - - August 22, 2014
    The original hand pump faucets for the 26X are no longer available and there have been some topics on this but I wanted to document my repair. I did some searching online and found a $20 replacement. The body is chromed metal with a robust metal acti...
