MacGregor 19 Rudders
- Boat Type: Boat Type
I did not like the way my Mac 19 steered. A buddy dropped off his Mac 26C, that I had sold him, for winter storage. I noticed the bottom of his rudder post was identical to the bottoms of my Mac 19's rudder posts. The top of the 26C post was open, so I drilled a 3/8" hole into the bracket on top of each of my Mac 19 rudder posts. Now I can drop a line down my rudder posts to use as rudder hold down lines, something the Mac 19 did not have.
Part of the steering problem on my 19 was the rudders lack of depth. So I am making a completely different rudder shape, more like on my Mac 26X. with a hole in the forward edge to attach the hold down line to. I'll tighten the pivot bolt so that they will stay down but kick up if they hit something.
Or, if they don't stay down, I'll wrap the hold-down line around a cleat in a circular way, as I've done on my other Macs (not a figure-8), so that if they do hit something the line will slip and the rudder(s) will come up.
Published by: Bill at BOATS 4 SAIL
Related Mods
Drainage HolesMiscellaneous - - December 1, 2019
Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
Boat CoverMiscellaneous - - December 1, 2019
The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
2:1 rudder single-loop uphaul downhaulMiscellaneous - - August 7, 2016
This is my implementation of the 2:1 mechanical advantage rudder lines. A single loop is used for both uphaul and downhaul. SeaSaw has stern-mounted seats, giving me a well-placed rail/stanchion around which the loop goes so it does not foul. Publish...
