Skegs
Published date: January 8, 2018
  • Boat Type: Boat Type
[IMG]http://i67.tinypic.com/2vcvqz9.jpg[/IMG]
[IMG]http://i63.tinypic.com/v5x445.jpg[/IMG]
I added skegs to my 26M to help with stability when motoring, not as good as having the rudders down but work very well in shallow water, even under sail with dagger board up light wind. I used 2 x 4 foam board epoxed over seems to be holding up . If I were to do it again I would try making them a little thinner more in the shape of the rudder. I lost about 1/2 MPH on the top
speed, but that could just be water or wind . So not much change.
Published by: Ponaldpe
Model Year: 2003
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • MacGregor 19 Rudders
    Miscellaneous - - December 28, 2017
    I did not like the way my Mac 19 steered. A buddy dropped off his Mac 26C, that I had sold him, for winter storage. I noticed the bottom of his rudder post was identical to the bottoms of my Mac 19's rudder posts. The top of the 26C post was open, so...
