Grounding for Ham or Marine sideband
Published date: February 21, 2018
  • Boat Type: Boat Type
RF (radio frequency) grounding on a Mac can be very challenging. The full glass hull, no metal keel, minimum and poorly grounded engine, no grounding of metal parts on deck make the Mac a real challenge.
I chose to try an approach that creates as much square footage of copper as possible while not attaching anything to the exterior of the hull.
My Mac 26M has a very dry bilge (or storage area). I chose to line my storage areas (hull side) with copper tape, 1 mil thick. You can buy this stuff from Amazon that is 6 inches wide and comes in 100 foot rolls giving you about 50 sqft of copper ground below water line inside the hull.
Both the total sqft and its capacitive effect with salt water provides for a very adequate ground.
Using a back stay wire antenna, antenna tuner, small amp and Ham radio I have successfully contacted people thousands of miles away with excellent signal reports across the ham bands from 80 meters through 17 meters.
This will work just as well with a marine sideband radio and proper antenna tuner.
Plus, it makes your bilge storage areas a nice shiny copper color!
Paula NX1P
Published by: paula_ke
Model Year: 2011
Photo Caption: Large Port Storage bilge
Small Port Storage Bilge
Aft Port Storage Bilge
Share
Related Mods
  • Electrical outlet near the dinette
    Electrical - (MacGregor 26X) - December 1, 2019
    A power outlet in the corner headroom/aft dinett seat/hull for mobile phone and everything else you might use while sitting by the dinett. Published by: MS Classifieds
  • Solar panels
    Solar panels
    Electrical - - December 1, 2019
    I installed 2 SOLAREX MSX 30 LITE solar panels on the hatch. They fit perfectly and leave enough space on each side for a teak grab rail in the future. Right now the panels are oversized (from the power point of view) since I do not have any big cons...
  • Lights & Electrical System
    We put in two additional interior lights. One over the rear berth, and one in the head. both are white plastic from West Marine, and have both the white and red bulbs (red reduces the impact on your night vision when you turn in on). The one in the h...
