Quick Release Pins
Published date: December 1, 2019
  • Boat Type: Boat Type
We all hate to mess with clevis pins right? Try ball lock pins. I use 1/4 " x 2" pins on the boom/mast gooseneck connection, the tack of the main, and to fasten the roller reefing drum to the bow. Never had one come loose but I recommned using long pins and install an elastic keeper on the pin ring. These REALLY speed up launching.
Pins can be ordered from M&E Marine. Item # 40736 @ 5.15 ea.
Also, install quick release lever at the base of the backstay. It significantly deceases the strain needed on the mast lowering system for releasing the forestay. M&E Marine Item # 43825 @ 38.95 ea.
Use quick release swivel snap shackles to connect the mast raising block to the foredeck and the main sheet block to the pedestal. These are rated at 2500 lbs. Model RF 6130 Order # 41130 @ 24.99 ea.
Lastly, add Pelican hooks to the aft end of the rear lifelines. Releasing the lifeline makes a world of difference when boarding the boat.
Published by: MS Classifieds
Model Year: 1998
Share
Related Mods
  • Correct Mast Raising Stay Design
    Rigging - MRS (MacGregor 26M) - January 30, 2020
    The 26M raising stays are not connected to the mast. This is easily rectified by connecting the stays at the mast raising bail. The problem is, the stanchion connection is not in line with the hinge pin at the mast step bracket. In this mod, I reloca...
  • sail pack
    sail pack
    Rigging - - January 7, 2018
    Sail pack kit from Sailrite, and self made lazy jack system. Published by: bobflshmn
  • Lazy jacks
    Lazy jacks
    Rigging - - May 8, 2017
    I have store-bought lazy jacks. I didn't want to have to take them off every time I stepped the mast (which, admittedly, only occurs twice a year) so what I did was make the D-straps on the underside of the boom detachable. Now, I can undo the D-stra...
