Ham Radio Aboard
- Boat Type: Boat Type
Ham radio aboard a sailboat can be difficult because of the all fiberglass hull. Good grounding, that is a good electrical connection to the earth, is not easy while sitting in a body of water, especially in my case fresh water. Salt water conducts electricity so a good connection over the side is easier, even trailing a copper wire in the water is better in salt water than on my lake. I used a combination of connecting to the exposed metal parts, hand rails etc and a counterpoise. A counterpoise is a set of wires cut for various frequencies bundled together in a tube and snaked along the side of the cabin, the longest wire about 20 feet. The end is connected to the ground lug of the antenna tuner. This combination together with a dipole hoisted to the mast top worked well enough to finish 16th in the ARRL Field day, a weekend test of radio in the field. Commercial counterpoises are available, but in my case being a ham, I made my own.
Published by: cooperstownsailor
Related Mods
Electrical outlet near the dinetteElectrical - (MacGregor 26X) - December 1, 2019
A power outlet in the corner headroom/aft dinett seat/hull for mobile phone and everything else you might use while sitting by the dinett. Published by: MS Classifieds
Solar panelsElectrical - - December 1, 2019
I installed 2 SOLAREX MSX 30 LITE solar panels on the hatch. They fit perfectly and leave enough space on each side for a teak grab rail in the future. Right now the panels are oversized (from the power point of view) since I do not have any big cons...
Lights & Electrical SystemElectrical - - December 1, 2019
We put in two additional interior lights. One over the rear berth, and one in the head. both are white plastic from West Marine, and have both the white and red bulbs (red reduces the impact on your night vision when you turn in on). The one in the h...
