Motor disconnect REMOTE
Published date: December 25, 2018
  • Boat Type: Boat Type
The BWY quick Motor disconnect ist great!!!
But it is quite bad to bring your head down to switch it on or off. Even worse if you have waves!
So with the handle I can grab it from the cockpit, sitting on the helm seat!
Worked great for 2 seasons now.
Published by: kurz
Model Year: 2011
Photo Caption: wonWeitem
Detail
Share
Related Mods
  • Steering Connector and Drainage Holes
    Motor - - December 1, 2019
    This picture shows the custom-built connector from the steering system to the engine. We started with a connector from the dealer, but it didn't fit right. We had a welder build a new one, and it works great! We leave the engine and rudders both conn...
  • Gas Tanks - Installation & Draining
    Note gas tanks on either side - these were there when I bought the boat. I believe they are 9 gallon tanks. The past owner had do some minor cutting to the openings to get them in. From there, he cut holes in the seat, put those plastic screw plugs i...
  • Outboard Motor Mount
    Motor - - July 9, 2017
    The previous owner of my 26D mounted the outboard to a retractable mount on the transom because he was a racer and wanted to make sure that the motor was completely out of the water. Unfortunately, wince I'm only 5'7", that put the outboard completel...
