Correct Mast Raising Stay Design MRS
Published date: January 30, 2020
Modified date: January 31, 2020
  • Boat Type: Raising, Mast, MRS, MacGregor 26M, Boat Type
The 26M raising stays are not connected to the mast. This is easily rectified by connecting the stays at the mast raising bail. The problem is, the stanchion connection is not in line with the hinge pin at the mast step bracket. In this mod, I relocated the stanchion connection loop to achieve proper alignment. After getting the stay lengths dialed in, I virtually eliminated mast side-play during raising/lowering.
I would encourage you to verify your final location. Not sure how consistently the factory located the stanchions or the mast step brackets.
Model Year: 2013
Photo Caption: Photos:
1. Loop removed
2. Align new location with mast step hinge.
3. Loop welded at new location. Note how much lower and further forward it has moved from the original location.
4. Finished for now with rough clean and polish.
5. New location is 2-3/4" up front brace - measured to upper attachment.
Share
Related Mods
  • Quick Release Pins
    Quick Release Pins
    Rigging - - December 1, 2019
    We all hate to mess with clevis pins right? Try ball lock pins. I use 1/4 " x 2" pins on the boom/mast gooseneck connection, the tack of the main, and to fasten the roller reefing drum to the bow. Never had one come loose but I recommned using long p...
  • sail pack
    sail pack
    Rigging - - January 7, 2018
    Sail pack kit from Sailrite, and self made lazy jack system. Published by: bobflshmn
  • Lazy jacks
    Lazy jacks
    Rigging - - May 8, 2017
    I have store-bought lazy jacks. I didn't want to have to take them off every time I stepped the mast (which, admittedly, only occurs twice a year) so what I did was make the D-straps on the underside of the boom detachable. Now, I can undo the D-stra...
