Shore Power 120v AC panel 26M Shore power
- Boat Type: Inlet, 120v, Shore power, MacGregor 26M, Boat Type
Marinco Stainless inlet, Blue Sea Systems AC Panel 8101 and outlets on a 2007 26M
The key to successful inlet placement when you have to cut the Large hole in the boat was to cut the panel hole first, remove all foam, make a template of the inlet size and do a pilot drill from the interior. When that is complete then you can do a holesaw cut from the outside.
I decided to route the wire through the back of the cavity into the head area and use PVC conduit rather than try to fish multiple AC lines inside the liner.
Related Mods
3D Printed West Marine Panel odElectrical - (MacGregor 26X) - August 7, 2020
I have three West Marine power panels in my 26x right now. I had only one small 4-switch one initially, but my system and needs have grown with my recent revising of the electrical system. I have an issue with these simple and inexpensive panels. Old...
Electrical outlet near the dinetteElectrical - (MacGregor 26X) - December 1, 2019
A power outlet in the corner headroom/aft dinett seat/hull for mobile phone and everything else you might use while sitting by the dinett. Published by: MS Classifieds
Solar panelsElectrical - - December 1, 2019
I installed 2 SOLAREX MSX 30 LITE solar panels on the hatch. They fit perfectly and leave enough space on each side for a teak grab rail in the future. Right now the panels are oversized (from the power point of view) since I do not have any big cons...
