Teak Hatch Tracks
- Boat Type: MacGregor 26X, Boat Type
Always hated the stock tracks. Finally realized that you can get to the 'hidden' nuts by removing the bolts to the head so that you can flex the fiberglass enough to access them.
Related Mods
Cork interiorCockpit - (MacGregor 26X) - March 27, 2021
Hi , for this decoration I used a 2mm thick cork roll and a slow-acting water-based glue.
Replace stuck steering wheel and Steering BrakeCockpit - 2002 (MacGregor 26X) - March 24, 2021
Wanted to add a steering brake to my upgraded steering system. Had to use a 3 jaw puller to remove the old wheel. Tried wd40, pb blaster both overnight. 1. Used 24in breaker bar to remove the old wheel nut. Stabilize wheel. 2. Sprayed pb blaster and ...
Hatchway DoorsCockpit - (MacGregor 26X) - August 17, 2020
As other owners have done, I've replaced the large white door that came with our '02 X. 3/4" plywood with 6 layers of spar urethane (the first 3 thinned 50% for absorption) and an oak piece for the overlap. Still need an inside latch or two when I fi...
