Head bifold/vberth door Head
- Boat Type: V-berth, Bifold, Head, MacGregor 26M, Boat Type
To add legroom in the head, I created a bifold door panel which I added to the main door on the inside out of 6mm marine ply I had left from another project. I used 3/4 wrap around hinge, which I installed backwards since both the main door and the extension fit in the slot. The door also works to close the forward v-berth area to give my girls (and us) a bit of privacy. Worked out pretty well, with little added weight.
Related Mods
Front SpeakersInterior - - December 1, 2019
We installed speakers in the vertical surfaces just above the v-berth. I would advise some caution when cutting the fiberglass as it is quite thin. Be sure to put the styrofoam back up in behind the speakers for floatation and to avoid the speakers s...
Communications/entertainmentInterior - - December 1, 2019
Greetings from Melbourne, Australia! I wanted to add music (radio/cassette/CD stacker) to 'Macanudo', my '97 26X. A 27Mhz radio was already installed hanging from a bracket just inside the companionway (hence there was power). It seemed a practical s...
